Thread: Adding persistent custom scales
    2009-04
    85
    Default Adding persistent custom scales
    Hi,
    I was wondering if it's possible to programmatically add persistent custom scales to a view (see picture attached). Or maybe it's possible through the view template ?
    There are some scales missing in the out of the box configuration, like 1:25 and 1:75 which could be interesting from a structural designer point of view.
    Thanks for your time,
    Buddy
    AUGI Addict jeffh's Avatar
    2002-09
    Manchester, NH
    1,087
    Default Re: Adding persistent custom scales
    Quote Originally Posted by some buddy View Post
    Hi,
    Buddy
    You can create custom scales but they are created per view and if you change the scale the custom value is lost. You can't make the custom setting available for all views
    2009-04
    85
    Thanks again Jeff.
  1. Allow "Custom Views Scales" to be available in the Properties of "Hide in Scales corser than"
    By autocad.wishlist1734 in forum Revit Structure - Wish List
    Last Post: 2011-10-07, 01:25 PM
  2. Adding New Scales to Scalelist using lisp
    By harilalmn in forum AutoLISP
    Last Post: 2011-02-04, 01:32 PM
  3. Custom Scales?
    By craighowie in forum Revit Architecture - General
    Last Post: 2011-01-19, 12:21 PM
  4. Adding persistent custom scales
    By some buddy in forum Revit - API
    Last Post: 2010-06-28, 03:25 PM
  5. Custom Scales
    By nsinha73 in forum Revit Architecture - General
    Last Post: 2007-05-31, 02:56 PM
