Thread: Adding persistent custom scales
    2009-04
    85
    Default Adding persistent custom scales
    Hi,
    I was wondering if it's possible to programmatically add persistent custom scales to a view (see picture attached).
    There are some scales missing in the out of the box configuration, like 1:25 and 1:75 which could be interesting from a structural designer point of view.
    Thanks for your time,
    Buddy
    2008-02
    58
    Default Re: Adding persistent custom scales
    In general the API doesn't allow you to customize existing UI elements in any meaningful way that I've found, however you can control the scale of a view in the API so it shouldn't be difficult to create an add-in which allowed you to establish custom scales and maintain them persistently.
    2009-04
    85
    Hi Abe,
    Thanks for the answer. Could you suggest how to accomplish this ? Something like pseudocode or even some chunks of code! I have some (very) basic knowledge of programming in Revit, but I spare the (re)search about how, what and where.
    Thanks again,
    Buddy
  1. Allow "Custom Views Scales" to be available in the Properties of "Hide in Scales corser than"
    By autocad.wishlist1734 in forum Revit Structure - Wish List
    Last Post: 2011-10-07, 01:25 PM
  2. Adding New Scales to Scalelist using lisp
    By harilalmn in forum AutoLISP
    Last Post: 2011-02-04, 01:32 PM
  3. Custom Scales?
    By craighowie in forum Revit Architecture - General
    Last Post: 2011-01-19, 12:21 PM
  4. Adding persistent custom scales
    By some buddy in forum Revit - Platform
    Last Post: 2010-06-28, 03:36 PM
  5. Custom Scales
    By nsinha73 in forum Revit Architecture - General
    Last Post: 2007-05-31, 02:56 PM
