patricks
You could do this... you just won't be able to see your DS locations in your roof plan unless you make them stick up through the top surface of your gutter solid.
With the normal gutter profiles, I just have the DS stick through the bottom slightly, which makes them visible in my roof plan if my view range is set correctly.
There are pros and cons to every different method, I think. If you do a custom line-based family, I don't think you can make it miter around corners, which is a big turn-off for me.
