I need to calc the weight of some framing, so in my schedule I selected Calculated Value, named it Weight. Why won't the formula accept Volume * 485 CF, but it will accept Volumne / 485 CF?
Rob
Rob
Just a weird Revit thing... caused by "Incosistent Units"
But try do divide one of the values by one (1), and have something like this:
Volume * (485 CF / 1) - It just MIGHT work
Still getting inconsistent Units (
Thanks though )
I'm not sure if it's a weird "Revit" thing as much as a "math" thing?
I believe Munkholm's on the right track, but the idea is to get rid of one of the units, i.e. Volume * (485 CF / 1 CF) ?
Also, make sure you're spelling "Volume" correctly in your actual formulas.
Edit: Also, I'm a little confused - you're trying to calculate the weight by multiplying two volumes? What value type are you using for the calculation?
Direct cut/paste from formula window
Still returns Inconsistent Units
Yeah, spelling can be an issue)
Unfortunalty, I'm helping someone else, so I'm not sure. Since volume is known, the weight is the result of the formula. I think CF was added to 485 just trying to make the unit consistent to get it to work.
Revit does NOT like *
Volume / Volume is acceptable
Volume * Volume returns Inconsistent Units.
What data type is the calculated value?
Assuming that the data type of the field named "Volume" is "volume",
if the data type of your calculated value is also "volume", use this:
Volume * 485
If the data type of your calculated value is "number", use this:
Volume * 485 / 1 CF
Revit is fine with " * "... it just has to be used correctly.
If Volume is actually a volume, and the value type is set to "Number", then you can use the "Volume / Volume" because the result is a "number" - the "volumes" cancel each other out.
In the same scenario, if you try to calculate "Volume * Volume", you'll get an error because the result is not a "Number" (again, I'm no math wiz, but I'm not sure that even makes sense).
If you really want to get to the bottom of this, I think you need to really lay out what each parameter is and what you're trying to do and/or post an example file.
Good luck to you!
