cliff collins
1.Have each user Synch to Central and relinquish all worksets.
2.Have each user close the project and Revit.
3.Have each user delete any local copies on their C: drives
4.Have each user open the Central File and click Create new Local.
5.Have each user Synch to Central, then relinquish.
This should clear up any strange behavior as you described.
Have each user open the Worksharing Monitor to see who has which worksets owned/borrowed. ( If you are not using this feature, you can download/install it
from the Autodesk Subscription Center.)
hope that helps.
cheers
