Thread: Transaction failure inside a transaction?
    2008-02
    58
    Default Transaction failure inside a transaction?
    I'm getting the standard "attempted to modify an object outside a transaction" however all modifications are done inside a transaction. From the error I suspect it may be that it's because I'm attempting to modify a component that is hosted inside another object and the scope of the transaction only include the component not the host object.
    Can anyone confirm or deny this?
    2006-08
    636
    Default Re: Transaction failure inside a transaction?
    Jeremy's blog has this issue covered in depth, perhaps you can do some search there, the building coder?
    2008-02
    58
    Ok, I changed the transaction mode from manual to automatic and it works, if I find out why it was failing at the Building Coder I'll post it here.
    2007-12
    Las Vegas, NV
    236
    Quote Originally Posted by abe.buckingham View Post
    Just be aware that your code will be outdated in future releases as they are stopping the automatic feature.
    2005-09
    69
    Quote Originally Posted by sgermano View Post
    I dont think so - I think its the automatic regeneration that is going to be stopped
  1. Replies: 2
    Last Post: 2012-05-01, 11:41 AM
  2. Replies: 0
    Last Post: 2012-04-25, 08:12 AM
  3. Replies: 0
    Last Post: 2010-10-08, 10:02 PM
  4. Replies: 0
    Last Post: 2007-04-27, 02:08 PM
  5. Replies: 0
    Last Post: 2006-10-12, 03:44 PM
