Hi Guys
I'm creating a tubular sweep that is going through 4 splines. See attached image.
The family file is also attached.
I've had a lot of problems in creating the sweep in the first place and if you increase the radius to be more than 210mm it breaks.
I’d be interested to see if anyone else is having problems in creating the form and also with increasing it’s Radius above 205mm.
Attached is the intended purpose for the trim which goes around a shell.
Thanks
Brian
