Results 1 to 6 of 6
Thread: Purge and/or Audit multiple files?
    AUGI Addict Maverick91's Avatar
    Grand Prairie, Texas, USA
    1,324
    Default Purge and/or Audit multiple files?
    I have a set of drawings I need to work with from a client. The drawings are made up of about 40 xrefs. I want to clean up the xrefs with Purge and Audit. Is there a way to do this clean up en mas, cleaning multiple files? Or am I left to go through each one? TIA.
    0,0,0 The Origin
    8,570
    Default Re: Purge and/or Audit multiple files?
    Use a script file - something like this -
    -purge
    all
    no
    audit
    yes
    1,324
    Quote Originally Posted by jaberwok View Post
    -purge
    all
    no
    audit
    yes
    Cool. I've got a couple of buttons on my tool palette that does this for individual DWGs. Is there a way to clean multiple files at one time?
    0,0,0 The Origin
    8,570
    I've never used it but others keep talking about Scriptpro.
    All AUGI, all the time Richard McDonald's Avatar
    2002-01
    At right angles to reality
    537
    Mav,
    "recoverall" should do the audit part of what you want.
    2005-09
    88
    Quote Originally Posted by Maverick91 View Post
    If you're willing to spend a little money, there are a couple of batch purge utilities available. I use Smartpurge from JTB software, and I've been very happy with it. It has a built in option to run an audit, among other things.
    http://www.jtbworld.com/smartpurger.htm
    I also have an audit and a purge included in my acaddoc.lsp. At the expense of a little bit more time taken every time I open a file, everything gets steadily cleaner as I work. that. combined with any scripting application that will open and save every drawing in a directory would do the trick.
  1. Purge & Audit all drawing files in a folder
    By rhayes.99001 in forum AutoLISP
    Last Post: 2019-03-01, 03:45 PM
  2. Purge + Audit &/or Recover + Purge
    Last Post: 2013-06-20, 08:18 PM
  3. Purge + Audit &/or Recover + Purge
    Last Post: 2013-06-19, 07:12 PM
  4. Cannot Purge or Audit File
    By kmarquis in forum Revit Architecture - General
    Last Post: 2010-02-09, 04:29 PM
  5. Bind, Purge, Audit.
    By daniel.mcging in forum AutoLISP
    Last Post: 2009-04-22, 11:51 AM
