I was able to change the units of my walls from mm to ft/in but all my doors, windows, wall types, etc are still all in mm. How can i switch them all to in/ft? Thanks for the help.
If I understand your post correctly, sounds like you are using the metric library. You need to use the Imperial library, instead. Try to use your installation disc to install it. Also, make sure the Project units are set to feet and inches.
thanks for the quick reply. i actually used the wrong template to start with. started a new drawing with an imperial template and its fine. thanks again.
