Our Standard font is SansSerif. When using the insert symbol pull down from MTEXT (or Unicode \U+2104), the symbol always defaults to ISOCPEUR. (I understand that SansSerif does not have this symbol so it uses a default font that has this symbol) I do not like the look of this symbol in ISOCPEUR font when its with SansSerif or the fact that it is compressed in height, I would much prefer the centerline symbol from ROMANS.
I have searched many forums and have not found that there is a way to specify what font to use when inserting a symbol. Does anybody know how to do this? I suspect I can delete the ISOCPEUR font from everybody's computer forcing it to go down the line to ROMANS but I don't like that solution. I also know that the Options > Files Tab > Text Editor, Dictionary and Font File Names > Alternate Font File variable does not appear to effect the symbol font.
I thought to look at the MTEXT pull down toolbar definition for the insert symbol command to see if the font is embedded into that command, but I didnt' have any luck down that path.
Does anybody have any ideas how I can dictate that our symbols are inserted within text as ROMANS instead of ISOCPEUR?
Thanks.
