Results 1 to 6 of 6
Thread: Door cut through multiple walls
    Turlock, CA
    6,420
    Default Door cut through multiple walls
    I'm modelling our office building and I found it difficult to model the many different conditions the architect created for the exterior walls. So I decided to use multiple parallel walls. Is there a way to get a door or window to cut through multiple walls that are beside each other? The only way I can think of is to place a door on one wall and then create openings in the other walls to look like the door cuts through them all.
    C:> ED WORKING....
    LinkedIn
    AUGI Addict cdatechguy's Avatar
    2006-10
    CdA, ID
    1,533
    Default Re: Door cut through multiple walls
    Join the walls together....
    I use this method quite a bit...
    Nevermind......wrong forum....lol
    Michael "MP" Patrick
    "I only drink :coffee: until it's acceptable to drink :beer: or :whiskey: or :wine:"
    I could stop if I wanted to Andy.88917's Avatar
    2005-06
    Midland, Texas
    230
    I do it all the time. Add an interference condition to the wall (or walls) not containing the door and use the door as the object to interfere. Not a problem!
    Turlock, CA
    6,420
    Excellent tip! Thanks.
    C:> ED WORKING....
    LinkedIn
    Turlock, CA
    6,420
    Have you been able to edit the endcaps created by the opening of an interference? I have air spaces between the walls that I need to wrap with gwb.
    C:> ED WORKING....
    LinkedIn
    Turlock, CA
    6,420
    The solution I came up with was to put the door/window in the wall that I need the gwb in. Then use the reposition within wall command to push the frame to the other side.
    C:> ED WORKING....
    LinkedIn
  1. Replies: 0
    Last Post: 2013-04-17, 04:46 AM
  2. 2012: 1 door 2 walls
    By POLYTEK in forum Revit Architecture - Families
    Last Post: 2012-04-10, 11:14 AM
  3. Anchoring a Door to Multiple Walls
    By dfsal in forum ACA General
    Last Post: 2010-03-25, 07:21 PM
  4. Door with no walls
    By belinda.66428 in forum Revit Architecture - Families
    Last Post: 2006-11-08, 12:54 AM
  5. 3 Walls, 1 Door
    By Matt Brennan in forum Revit Architecture - Tips & Tricks
    Last Post: 2005-09-04, 07:17 AM
