Thread: Link 3D AutoCAD geometry into Revit
    2009-09
    Grafton, Wisconsin, USA
    10
    Default Link 3D AutoCAD geometry into Revit
    I need to link (or import) some complex conveyor belt systems into my Revit Architecture model. The consultant we're working with draws all the conveyor systems as 3D objects in AutoCAD. What I've tried so far, that seems to work best, is to start in Revit, go to File > Import/Link > CAD Formats, then select the DWG file. I select "link" in the Import/Link CAD Formats dialogue box, and leave the rest of the options at their default settings. After several moments the 3D geometry is imported, but I get a warning saying "Some ACIS objects could not be imported. To import them, use AutoCAD to convert them into polymesh objects and reimport." The result is pretty good, except that there are portions of the DWG file that are missing, which I assume are the problem objects from the DWG file.
    I tried using 3DSOUT in AutoCAD, then starting a new AutoCAD drawing and then importing the 3DS file (based on advice found in another thread) http://forums.augi.com/showthread.php?t=101085
    But the import didn't bring in any geometry. It was supposed to convert the 3D objects to solid geometry. Not being familiar at all with 3D objects in AutoCAD, how can I make this work?
    I'm using AutoCAD 2008 and Revit Architecture 2009. No possibility to upgrade at this time, so any suggested solutions that work with these versions would be very helpful.
    Chris Kline, AIA, CDT, LEED AP
    2011-08
    Default Re: Link 3D AutoCAD geometry into Revit
    I have been going thru a similar thing and found that from w/ in Revit, on the INSERT ribbon, there is the IMPORT CAD item.
    it imports everything in the file you point it to.
    For the conveyor i imported, i have the "structure" itself that came thru, it's just the rendering aspects that are not right. Meaning, everything is system green and i can seem to change it, so far.
    But anyway, the IMPORT did work.
    Hope that helps
    All AUGI, all the time Alex Page's Avatar
    2004-03
    Wellington, New Zealand
    822
    not that this answers your questions, but I would suggest importing your CAD file into a Revit Family and then loading the revit family into your model..why?
    1. Your family is then on the correct category
    2. Revit seems to show 3d CAD objects better when in a family: it gets the cut plane correct etc whereas if linking a 3d CAD model directly into your project the cutplane quite often is incorrect.
    Alex Page
    RevitWorks Ltd
    Check out the Door Factory, a door maker add-in for Revit
    2012-12
    4
    In AutoCAD, export your file as an autocad file, then when you link it into revit, it will show all ACIS Objects
  1. 2014: Revit novice; Revit link to rvt file has "Import Geometry Not Visible" error
    By stircrazy in forum Revit Architecture - General
    Last Post: 2014-01-10, 01:28 AM
  2. 2013: How to Import (not link) Revit geometry
    By jeff.95551 in forum Revit Architecture - General
    Last Post: 2013-03-18, 07:50 AM
  3. Replies: 0
    Last Post: 2012-01-11, 09:42 PM
  4. Modifying Geometry in ROBOT and Updating Geometry in REVIT
    By stephen.lewis in forum Robot Structural Analysis
    Last Post: 2009-12-09, 04:32 AM
  5. Import/Link AutoCAD to Revit
    By jdbejk in forum Revit MEP - General
    Last Post: 2008-05-16, 06:29 PM
