Thread: Pipe Label Anchor location
    2003-11
    281
    Default Pipe Label Anchor location
    I have a pipe profile label style with the default anchor option set to "Graph view bottom". How do i get my dimension anchor value to be 10mm above the Graph bottom without changing them manually in the property editor after creation?
    I've tried changing it in the "Default Profile Label Placement" options of the Pipe network command settings but it doesn't work.
    2006-12
    Loveland, CO
    734
    Default Re: Pipe Label Anchor location
    There is no option to say, "I want it Xmm above/below the graph bottom/top". You have to anchor it to the graph top. If you want it to display Xmm above/below the graph bottom/top, you'll need to set up your style to display that way.
    Brian J. Hailey PE
    CAD-1
    Civil3D PLUS My blog
    At Your Desk Training
    2003-11
    281
    Really? Because you can change it Xmm after they are created by selecting the label and changing the dimension anchor value in the properties palette.
    The reason i didn't want to change the label style was so that i could have the grip on the dim line and in the event that if i did have to move the label i could snap it to a grid line and maintain that "drafting consistency" throughout.
    Not a big deal; I'm just trying to get the most out of it.
    Take care,
    2006-12
    Loveland, CO
    734
    Well, if you find it, let us know. I would be interested to see if it's possible. Everywhere I've looked, I can't find a setting for it.
    Brian J. Hailey PE
    CAD-1
  1. Annotative Location of Duct Label Curve
    By buzz in forum AMEP General
    Last Post: 2010-02-03, 05:46 PM
  2. structure label dimension anchor point-profile view
    By Fred.Spinnenweber in forum AutoCAD Customization
    Last Post: 2008-04-17, 03:28 PM
  3. Reference Label Location Problem
    By bowlingbrad in forum Revit Architecture - General
    Last Post: 2006-12-29, 06:06 PM
  4. Controlling Label location
    By Gordon.Price in forum Revit Architecture - Families
    Last Post: 2006-11-22, 01:50 AM
