Thread: Problem with lights when rendered
    2010-07
    Unhappy Problem with lights when rendered
    Hi friends,
    I have this problem with lightings that when I render the active viewport I don't get the lighting and its completely dark. But if I select some objects and render them alone then I can see that the lighting is rendered properly. Keeping the render area as 'selected' I tried to select a whole group of objects and then render but again it is darkness.
    I don't know what kind of problem this is. I have tried almost all options known to me. I am using 3d max design 2010 and also tried doing it in max 2011 only to learn its not working.
    This problem applies to all kinds of lighting except daylight..why is that? Is there a setting that I might have changed accidentally?..or anything else. Please help me
    Thanks in advance
    rgds,
    Vivek.B
    2007-08
    Denver, CO
    334
    Default Re: Problem with lights when rendered
    It could be that you need to set your exposure (in the environment panel) for the appropriate type of lighting. Is it an exterior or interior scene?
    2010-05
    2
    hi friends,
    i have problem in when i import autocad file in 3ds max2011, it looks fully dark (black). and when i render it no light is working, i previous versions of 3ds max it worked but in 3ds max 2011 it doesn't work.
  1. 2013: Interior Lighting - lights stay dark when rendered
    By silversurfer790 in forum Revit Architecture - General
    Last Post: 2013-10-04, 06:38 PM
  2. problem exporting rendered images?
    By markcrabbe01 in forum Revit Architecture - General
    Last Post: 2009-11-30, 01:08 AM
  3. Creating a Rendered Image Problem
    By paul.mawson in forum NavisWorks - General
    Last Post: 2008-05-20, 11:11 AM
  4. Weird problem with rendered views on sheets
    By iankids in forum Revit Architecture - General
    Last Post: 2007-11-23, 09:07 AM
  5. Rendered Material Problem
    By jhuynh in forum Revit - Rendering
    Last Post: 2006-02-03, 09:53 PM
