Thread: AutoCAD 2010
    Question AutoCAD 2010
    When linking an Excel Spreadsheet to AutoCAD 2010, do you have to change the format of the text in Excel for it to come in at the correct scale in CAD?
    6,409
    Default Re: AutoCAD 2010
    With OLE objects AutoCAD knows nothing about scale. It only knows the size of the bounding box. Everything inside that is handled by xl. The concept of OLE is that a container object delegates all actions to the linked object. You can increase the 'scale' in acad by making the box bigger. To 'zoom' in, select fewer cells in xl.
    Unless you are talking about linking a table to xl? In that case, only the data is obtained from xl and table formatting is controled through normal table formatting.
    LinkedIn
    2015-11
    Jo'burg SA
    4,512
    If it is the table thingy (not OLE) and you pasted a link with As AutoCAD entities, then it usually comes in with some of Excel's formatting (usually WRONG). You'll need to modify the link with the DATALINK command and edit the pasted Excel link (warning it's SLOOOOW). Do some testing on which settings make for best format.
  1. Replies: 2
    Last Post: 2010-06-29, 08:26 PM
  2. How to Update Serial Number in RAC 2010 Like in Autocad 2010
    By bingles7 in forum Revit Architecture - General
    Last Post: 2009-11-22, 05:06 PM
  3. Major Crash - Unable to re-open RSA, Revit 2010 & AutoCAD 2010
    By swmarais in forum Robot Structural Analysis
    Last Post: 2009-10-29, 05:52 AM
  4. Replies: 0
    Last Post: 2009-10-22, 02:18 PM
  5. Major Crash - Unable to re-open RSA, Revit 2010 & AutoCAD 2010
    By swmarais in forum Revit Structure - General
    Last Post: 2009-10-22, 02:15 PM
