Thread: Drawing list & Key Plans
    2010-07
    4
    Default Drawing list & Key Plans
    Hello Everyone,
    I am very new to Revit. In fact I have not yet work on
    a revit project in my office. But I have read/watch a lot
    of tutorials, blogs, etc.
    I edited a titleblock family to include a key plan. I added
    a parameter called key plan. Family parameter->Visible,
    Paramerter type->Yes/No. I changed the key plan elements
    (lines) to this parameter.
    I loaded the titleblock family back to my project and it works fine. I
    can turn the visibility of the key plan on or off in the sheets.
    My question:
    Is there a way to schedule this so I can just do it in the schedule
    instead of going to each sheet & turn off the visibility of key plan
    if the sheet does not required it.
    I created a "drawing list" schedule but I dont know how to hook-up
    the titleblock parameter. Can this be done?
    Any help or ideas will be appreciated. Thanks.
    2000-01
    Seattle WA USA
    5,857
    Default Re: Drawing list & Key Plans
    If you had made the parameter a shared parameter, you could have added it to the model as a project parameter which can be used in schedules.
    R. Robert Bell
    Design Technology Manager
    Stantec
    2010-07
    4
    Robert,
    I'm having no luck with shared parameters.
    This is what I did.
    1. I drew the key plan in the titleblock family but found out I could not create a shared
    parameter within an annotative family. The shared parameter button was grey-out.
    (I erased the key plan).
    2. I drew the key plan in a detail component. Then I was able to create a shared arameter.
    Parameter Group: Titleblock, parameter name: Key Plan.
    I changed the key plan elements to the shared parameter. I saved the detail component
    as a family. Then tried to load it to the titleblock (annotative family) but it did
    not allow me.
    What am I doing wrong. I must admit this was a good exercise for me about parameters.
    If you get a minute could please briefly explain/instruct me on what to do.
    I think scheduling key plans for sheets would be very powerful.
  1. Improve Drawing List to customize drawing order, discipline, etc
    Last Post: 2012-09-25, 05:02 PM
  2. Export plans from drawing sheets with shared co-ordinates
    By pfaudler in forum Revit Architecture - General
    Last Post: 2008-04-01, 11:03 AM
  3. 2 floor plans viewed in 1 drawing in plan view
    By Bill.Jensen in forum ACA General
    Last Post: 2007-03-01, 06:50 PM
  4. Drawing existing plans
    By tim.101799 in forum Revit Architecture - General
    Last Post: 2007-02-14, 01:43 PM
  5. Replies: 4
    Last Post: 2005-02-08, 05:20 PM
