Thread: ACA 2010 - Install express tools after install
    2010-04
    11
    Default ACA 2010 - Install express tools after install
    Hi. I have a computer that ACA 2010 has been installed without Express tools. I went into Change Programs to change and add the feature but i am prompted for the CD. My IT guy tells me we have a subscription so we dont have the cds. Is there a way I can install this without or do i need to reinstall ACA all together?
    2010-06
    14
    Default Re: ACA 2010 - Install express tools after install
    Quote Originally Posted by shane.249457 View Post
    I have a similar problem finding Express Tools; Is there somewhere I can download them? it?
    ACA Community Director dkoch's Avatar
    2003-03
    Going for a long walk off a short pier
    1,848
    You may not have CD's, but you must have downloaded an installation file and/or created a deployment. Is the file from which the program was installed still in the same place as when you installed it? My experience has been that in that case, you can do repair installations or reinstall and add uninstalled features.
    If the installation file has moved, if you still have access to it from your computer, does it allow you to point to the new location, or is inserting the CD the only option?
    David Koch
    2010-06
    14
    For some reason it doesn't locate the files it wants from the CD.
    I don't want to reinstall anything - I've done so much customizing - and I'm not very good at, and haven't had much success in the past, saving the correct mnu files for the re-installation process.
    Very busy, please help.
  1. Can I not install 2010 32 bit on a 64 bit OS?
    Last Post: 2009-05-28, 03:07 PM
  2. Install Express Tools with AutoCAD 2005
    By CadDog in forum AutoCAD General
    Last Post: 2006-03-22, 07:45 PM
  3. How to install Express Tools
    By marine_designer in forum AutoCAD General
    Last Post: 2005-09-09, 07:01 PM
  4. AutoCAD 2004 - Install Express Tools
    By tflaherty in forum AutoCAD General
    Last Post: 2005-06-03, 08:40 PM
