Results 1 to 10 of 12
Thread: Dots in a sectional pipe
    AUGI Addict Cosmo's Avatar
    2003-02
    Syracuse, NY
    1,122
    Default Dots in a sectional pipe
    Has anyone fixed this? when you have a pipe rise, and the rise extends past the cut plane, Revit adds that dot...it's not the centerline...it's just a dot. Anyone dealing with this?
    I could stop if I wanted to gabecottam's Avatar
    2006-10
    236
    Default Re: Dots in a sectional pipe
    Picture?
    I'm not sure I've ever seen what you are talking about.
    Gabe Cottam . . . . Sr. AEC Application Engineer . . . . ProSoft
    Active Member Maxime S's Avatar
    2008-03
    Montréal
    95
    See attached screenshot for what Cosmo probably described.
    Cosmo, I haven't found a way to get rid of these
    Maxime Sanschagrin
    Wannabe BIM Manager
    Teknika HBA, Montréal
    2006-10
    236
    I don't see those when modeling in "Thin Lines" or on my prints?
    Are they printing? - Or are they just an annoyance on the screen when "Thick Lines" are on?
    2008-03
    Montréal
    95
    They do print And yes, they are only visible when Thin Lines are off.
    Maxime Sanschagrin
    Wannabe BIM Manager
    All AUGI, all the time Jrobker's Avatar
    2005-08
    11,000 feet atop a chute
    955
    Those dots have the most unusual behavior.
    It all depends on how much pipe (riser) is above or below the top of the primary range.
    If the top of the pipe is below the top range than no dot.
    If the top of the pipe is 5' above the top range and the bottom is 5' below than half moon
    If the top of the pipe is 15' above the top range and the bottom is 5' below than 3/4 moon
    If the bottom of the pipe is 1" below the top range and 4' above than full moon (sometimes I feel like giving to Adesk).
    Go on, play with it and see if it makes any sense to anyone.
    There is no way to remove it and it will not print.
    JR
    "Keeping my view range hopeful."
    2006-10
    236
    One more reason why we LOVE Revit!
    2008-03
    Montréal
    95
    Quote Originally Posted by Jrobker View Post
    Well, I just made another test here, and they DO print... I'll play with my settings to see if I can get "rid" of them when printing...
    Maxime Sanschagrin
    Wannabe BIM Manager
    2003-02
    Syracuse, NY
    1,122
    Quote Originally Posted by cad-max View Post
    Thanks guys, that is exactly what I am talking about. and... yep they print allrighty. outside of the horrific solution of adding a masking region (or about 800 of them) I'm stumped. Cranking the cut plane works, but, of course at the detriment to the rest of the view.
    2006-10
    236
    Hmm, that is strange. We've never had them print here.
  1. 2011: Pipe-in-pipe, containment pipe, double-wall pipe ?
    By Super T in forum Revit MEP - General
    Last Post: 2011-08-17, 01:42 PM
  2. Sectional Perspective - controlled
    By boyd.112779 in forum Revit Architecture - General
    Last Post: 2007-09-13, 03:34 AM
  3. Sectional Views?
    By -OTTP-Brembo in forum Revit Architecture - General
    Last Post: 2005-05-06, 01:57 AM
  4. array - Sectional Door
    By ihammerhands in forum Revit Architecture - General
    Last Post: 2004-06-23, 01:53 PM
