Thread: Adaptive Component VS Mass
    2005-04
    230
    Default Adaptive Component VS Mass
    Hi there.
    I am busy playing with the Conceptual Mass Tool and see that there are two options available when making a Conceptual Mass Family.
    Either 'Adaptive Component' or 'Mass'.
    In what instance would one use an Adaptive Component?
    Craig
    2003-04
    Chino, CA
    4,756
    Default Re: Adaptive Component VS Mass
    Adaptive components can be applied to a Mass when one needs an object which will adapt to a shape as it changes. For some really good examples and videos, go to http://buildz.blogspot.com/
    2005-04
    230
    Hi Scott
    Oh okay I understand now!
    Thanks
  1. 2014: Facade Frame Adaptive Component
    By jagostinho in forum Revit - Conceptual Design Tools
    Last Post: 2015-07-07, 11:09 AM
  2. 2015: BIM object in adaptive component?
    By kerber.g685733 in forum Revit Architecture - General
    Last Post: 2014-12-17, 09:54 PM
  3. 2015: Cannot repeat adaptive component
    By plainold804808 in forum Revit - Conceptual Design Tools
    Last Post: 2014-12-16, 06:04 PM
  4. Adaptive Component Tree Column.
    By craighowie in forum Revit - Conceptual Design Tools
    Last Post: 2010-10-18, 02:09 AM
  5. UV grid by intersection + Adaptive component
    By pfaudler in forum Revit - Conceptual Design Tools
    Last Post: 2010-10-12, 01:40 PM
