Thread: Remove all constraints in AutoCAD 2011
    2002-10
    154
    Default Remove all constraints in AutoCAD 2011
    Is there a way to remove all constraints? I create a drawing and started using constraints. I probably have between 40 to 75 constraints in the drawing. I have tried to right click on each constraint and select delete but they still appear for a second when a view port regens it's view then they vanish. This leads me to believe that they are not completely removed.
    I tried saving as older versions (even back to R14 dwg) but they still appear when I reopen the file. I can try to save as V12 dxf but I will loose my xrefs, annotation, dynamic blocks, etc...
    I would think that it would be my computer but it is a new system. I am using Windows 7 64bit operating system on a quad core Xeon W3530 2.80GHz with 8GB Ram and a 1GB ATI FirePro V4800 (AutoCAD recommended video card). It is not the best, but not too bad of a system. I think that I just over did it with the constraints.
    2009-01
    7
    Default Re: Remove all constraints in AutoCAD 2011
    DELCONSTRAINT at command line
  1. Replies: 0
    Last Post: 2015-08-07, 03:55 PM
  2. Replies: 0
    Last Post: 2015-08-07, 03:47 PM
  3. Remove All Geometic Constraints
    By Bolknack in forum AutoLISP
    Last Post: 2012-11-30, 07:06 PM
  4. Where is AutoCAD 2011 in the AutoCAD Revit Structure Suite 2011 bundle?
    By Dariusz.Kwolek in forum AutoCAD Structural Detailing
    Last Post: 2010-04-26, 09:42 AM
  5. remove all constraints at once?
    By timothyjturner in forum Inventor - General
    Last Post: 2009-01-06, 09:22 PM
