Thread: Rigged/Animated Character Export to Max 2010?
    I could stop if I wanted to loydg's Avatar
    2007-08
    Denver, CO
    323
    Default Rigged/Animated Character Export to Max 2010?
    We have a request from a client who wants to see a 3D deer crossing at a proposed wildlife crossing. I did some searches for good rigged and animated 3D deer models. There is one that really rocks and comes with a ton of good animation. Only problem is it's in Maya format only and we are a Max shop (witha couple Maya licenses). Before we pitch buying this model I wanted to check to see if it's possible to export the rigging to 3DS Max 2010. If so, what level of effort are we looking at?
    Much appreciated!
    Glen Loyd
    Parsons Brinckerhoff
    Lead Design Visualization Specialist
    3ds Max Design 2010 Certified Associate/Professional
    www.pbprojectviz.com
    www.pbviz.com/forum
    Administrator Steve_Bennett's Avatar
    2004-05
    Somewhere near there
    4,627
    Default Re: Rigged/Animated Character Export to Max 2010?
    Quote Originally Posted by loydg View Post
    Much appreciated!
    From what I understand about the fbx format, you "should" be able to export the geometry and animation assigned to it to max. I'll try and find out from a maya expert at Siggraph tomorrow if I can get an ear.
    Steve Bennett / CAD Manager
    HMC Architects / Adventures in BIM
    2004-05
    4,627
    I talked with a few of the whizbangzoom experts at Siggraph yesterday about this. They said it should work, "knock on wood", if the model is for purchasable download. The model, rigging, animation assigned, lights, cameras and all that should come through. The only thing that won't transfer through from maya to max is materials. Sucks, I know. The materials in the 2 platforms are totally different and continue to evolve so it would be quite the undertaking to write code to translate materials from one to the other.
    2007-08
    Denver, CO
    323
    Thanks for digging, Steve. I chatted with our only Maya guru in DC and he said pretty much the same thing. He was skeptical that the bones would come through properly though. Redoing the materials is pretty much a given. We were also discussing "baking" in the animation as key frames. It would limit us to a looped walk cycle, but better than nothing. Final option would be to export out the terrain and render the deer from Maya and composite...
    Hope you had a blast at SIGGRAPH....
    Glen Loyd
    www.pbviz.com/forum
  1. Revit 2010 Export to DWF
    By rross.108280 in forum Revit - API
    Last Post: 2010-07-28, 03:10 PM
  2. IFC Export 2010 and 2011
    By christopher.carlsson in forum Revit Architecture - General
    Last Post: 2010-04-28, 07:18 AM
  3. DWF or DWFx Export in 2010 a bug?
    By Silleke in forum Revit - Plotting/Printing/Exporting
    Last Post: 2009-09-28, 11:12 AM
  4. Revit 2010: BUG - Export to NWM 2010. World units problem
    By sinzoff in forum Русский - Revit
    Last Post: 2009-05-22, 10:26 AM
  5. How to Export Animated Hoses
    By stusic in forum 3ds Max - General
    Last Post: 2009-05-13, 04:40 PM
