Thread: Adding additional beams to beam system
    2006-12
    90
    Default Adding additional beams to beam system
    In RAC2011, is there any way to add additional beams to a beam system?
    You can unpin existing beams and move them around, but can you add additional beams, similar to adding a custom grid / mullion to a curtain wall?
    2006-12
    90
    Default Re: Adding additional beams to beam system
    Ok, so you can unpin, move and re-pin a beam and it is still associated with the system.
    But if you 'copy', it seems to lose its association to the system?
  1. Coping Beams (Beam-To-Beam)
    By sdijanovic1583519 in forum Revit Structure - General
    Last Post: 2011-09-25, 07:10 PM
  2. Beams not showing in beam system
    By Eric Stewart in forum Revit Architecture - General
    Last Post: 2007-11-23, 02:17 PM
  3. Beam system - no beams at the ends
    By johk in forum Revit Structure - General
    Last Post: 2007-10-18, 06:31 PM
  4. using the beam system tag on beams that wern't created with the system tool
    By khanson-3b in forum Revit Structure - General
    Last Post: 2006-08-16, 02:47 PM
  5. Adding additional Attributes
    By sirdrumsalot in forum AutoCAD General
    Last Post: 2005-10-21, 07:18 PM
