Thread: Multi Spline Sweep - Adaptive Component
    2007-02
    Melbourne
    226
    Default Multi Spline Sweep - Adaptive Component
    Hi Guys
    I'm creating a tubular sweep that is going through 4 splines. See attached image.
    The family file is also attached.
    I've had a lot of problems in creating the sweep in the first place and if you increase the radius to be more than 210mm it breaks.
    I’d be interested to see if anyone else is having problems in creating the form and also with increasing it’s Radius above 205mm.
    Attached is the intended purpose for the trim which goes around a shell.
    Brian
    2010-03
    20
    Default Re: Multi Spline Sweep - Adaptive Component
    First of all, a used the family as you gave to us and theres the same problem.
    I dissolved and change the radius to 500. And after that, I created the form, and it work. Maybe creating spline by spline sweep it should work.
  1. 2015: BIM object in adaptive component?
    By kerber.g685733 in forum Revit Architecture - General
    Last Post: 2014-12-17, 09:54 PM
  2. 2015: Cannot repeat adaptive component
    By plainold804808 in forum Revit - Conceptual Design Tools
    Last Post: 2014-12-16, 06:04 PM
  3. 2012: Custom Spline Leaders Via Adaptive Components?
    By r.grandmaison in forum Revit Architecture - General
    Last Post: 2012-06-08, 03:19 AM
  4. UV grid by intersection + Adaptive component
    By pfaudler in forum Revit - Conceptual Design Tools
    Last Post: 2010-10-12, 01:40 PM
  5. Adaptive Component VS Mass
    By craighowie in forum Revit Architecture - General
    Last Post: 2010-07-14, 08:18 PM
