Thread: Error 1606 Autodesk Raster Design 2011 when installing
    2007-10
    NL
    6
    Default Error 1606 Autodesk Raster Design 2011 when installing
    To All,
    Do anybody have a solution for this,
    "Error 1606. Could not access network location Autodesk\ARD2011\R18.1\enu\"
    during installation of Autodesk Raster Design 2011.
    I have already check my user profile and that is oke.
    Regards,
    Gerry
    AUGI Addict Railrose's Avatar
    Abilene, TX
    1,180
    Default Re: Error 1606 Autodesk Raster Design 2011 when installing
    We haven't received our packages yet, so I can't be of specific help. I do know that when I loaded 2010, I had to uninstall 2009.
    You might be able to do a "repair" from the disk. If that doesn't work, you might try to uninstall & reinstall the 2011 version. If that doesn't work, you may have to uninstall previous versions & reinstall as a last resort.
    Give people a job worth doing, the tools to do it, recognition of a job well done & get out of the way.
    South Eastern US, exact location unknown
    1,376
    Are you installing from the DVD or d/l?
    If from the dvd copy the files to the hard drive and try that.
    I used the d/l files with no problems 2 -3 times
    J. Murphy
    AKA
    Murph
    The former AutoCAD MAP3D Power User
    2007-10
    NL
    6
    Quote Originally Posted by Jmurphy View Post
    I already try this before I post this Thread.
    Thx
  1. Fatal Error in AutoCAD after installing NavisWorks 2011
    By knorris in forum NavisWorks - General
    Last Post: 2010-11-01, 12:21 PM
  2. Autodesk Raster Design
    By serg5255 in forum Русский - AutoCAD
    Last Post: 2010-10-29, 07:59 AM
  3. Raster Design 2010 error
    By Railrose in forum Raster Design - General
    Last Post: 2010-04-28, 03:59 PM
  4. Autocad + Autodesk Raster Design 2009 - Falha na instalação
    By szanini in forum Português - AutoCAD / AutoCAD LT
    Last Post: 2008-05-31, 07:59 AM
  5. Strange Error on Raster Design?
    By jonathan.landeros in forum Networks
    Last Post: 2005-11-18, 01:54 PM
