Results 1 to 10 of 10
Thread: How to reduce file size in AutoCAD
    2006-08
    3
    Default How to reduce file size in AutoCAD
    Hey,
    I usually create 3D model of Aeroplane and for me file size is very important. I want to reduce the file size as per as possible. I usually create the profiles of the aeroplane and loft it. I take minimum sections to reduce the size. Still file size is big. Can you give me some tips to keep the file size minimum.
    Best regards,
    Shanower
    2009-11
    5,719
    Default Re: How to reduce file size in AutoCAD
    Quote Originally Posted by shanower_buet View Post
    Hey,
    Best regards,
    Shanower
    Maybe I misunderstood you, but it sounds like you are placing three groups of data in the same drawing... plan (top), profile (side), and section (elevation). *If* that is correct, you can reduce files size in the way you work, by placing each category in it's own separate drawing. If you need to work on one while referencing the data from another, use XREF.
    Regardless of my first comment, try vla-purgeall to reduce file size before saving the drawing.
    For the best possible solution for your situation, you might want to post a sample drawing. Allowing us to see what you're working with, might reveal other suggestions.
    Cheers!
    Computer Specs:
    2010-06
    962
    Hello mat.
    I think he indicates to the file size of the Autocad file as shown in the following image.
    Best regards
    Tharwat
    2009-11
    5,719
    Quote Originally Posted by tharwat313 View Post
    ...I think he indicates to the file size of the Autocad file as shown in the following image.
    Hi Tharwat,
    Maybe it's just an early Sunday morning for me (still groggy), but what other *file size* is there?
    Aside from some best practices, like not having duplicate lines, etc. I'm not sure what else you mean.
    Computer Specs:
    2010-06
    962
    Hi mat.
    May be he is suffering from the increasing of the file, and since that he is dealing with 3d Plans
    which required big capacity of Memory, besides that , the rendering also would make him angry due to the long time that it would take.
    Best regards,
    Tharwat
    2006-08
    3
    Hi,
    That is true. The file size becomes huge when I create 3D model of aeroplanes. I want to minimize it. I want to maintain the file size within 300-400 KB.
    Regards,
    Shanower
    Hi mat.
    Best regards,
    Tharwat
    0,0,0 The Origin
    8,570
    Why would the OP have "three groups of data" in a 3D model?
    If it is a model, file size is simply a function of model complexity - oh, and whether or not the model's history has been kept.
    2009-11
    5,719
    Quote Originally Posted by jaberwok View Post
    That was me, not fully awake yet.
    Quote Originally Posted by RenderMan View Post
    Yes, in a 3D drawing it is one contiguous model, or a series of the same. Whereas in a 2D model each *category* is usually kept within a separate drawing.
    Computer Specs:
    0,0,0 The Origin
    8,570
    Ah. Sorry, it's been a long week.
    2009-11
    5,719
    ... You too!?
    Computer Specs:
  1. Methods / ways to reduce DWG file size
    By don.gryder in forum AutoCAD General
    Last Post: 2013-03-14, 02:15 PM
  2. 2011: How to reduce file size in AutoCAD
    By shanower_buet in forum AutoCAD General
    Last Post: 2013-03-14, 01:33 PM
  3. How can I reduce the size/polycount of my file?
    By comical_wenger in forum 3ds Max - General
    Last Post: 2010-10-19, 03:50 PM
  4. Reduce CAD file size before linking
    By Chirag Mistry in forum Revit Architecture - General
    Last Post: 2007-10-12, 07:44 PM
  5. Reduce the File size...
    By Cyril Verley in forum Revit Architecture - Tips & Tricks
    Last Post: 2005-06-28, 09:53 PM
