What is the trick to selection and working with shafts? Can they be made visible for the purpose of working with they? Thanks.
To make it easier to select, add symbolic lines in the sketch. Tab-select until you can select the shaft, edit the sketch, and then add symbolic lines while in sketch mode, such as the normal standard of an "X" drawn through the opening.
OK, i have added the symbolic lines. But they only show up on the 2nd opening (it cuts through 2 floors). I can easily select it on that level. But how can I get the symbolic lines to show on all floors? Thanks.
Never mind, It was in the Visibility Graphics dialog. Thank you!
