Results 1 to 6 of 6
Thread: convert to bitonal image
    2008-12
    11
    Angry convert to bitonal image
    i hav a sid file, 1.5 GIG, converted it to a JPG 8 GIG, this is stripped . i need to plot it in black and white. when i attempt to launch the historgram the prograr crashes. any assistance would be apprecieated.
    civil 3D, Raster, 32 Bit
    TN/KY Area
    1,632
    Default Re: convert to bitonal image
    Try using the Change Color Depth "IDEPTH" then the Bitonal option under Process Image tools. Then you may need to use the invert under the cleanup tools.
    J. Murphy
    AKA
    Murph
    The former AutoCAD MAP3D Power User
    Forum Manager, Administrator Ed Jobe's Avatar
    Turlock, CA
    5,328
    Also, I find that if you do this in one step, i.e. go from a high depth down to 2, you may loose a lot of quality. The same with going from a high resolution to a low one. I sometimes do this in intermediate steps.
    C:> ED WORKING....
    2008-12
    11
    I get a fatal error C3D out of memory then it crashes.
    TN/KY Area
    1,632
    Quote Originally Posted by rschaff View Post
    That can be expected with a large image file on a 32 bit system. First turn off the 3 gb switch if you have it on. Second free up some memory and try to increase your page files. Clean out the user temp folder (Start > Run> tpye in "%temp%" w/o quotes, and delete all the files there you can. Then use the image options from the map tools and look at the memory tab, there's a few changes you can make there to boast the image performance temporary. Read the help on that tab and clear out that cache as well.
    J. Murphy
    AKA
    Murph
    Turlock, CA
    5,328
    Check the size of your swap file too when you are looking for more memory.
    C:> ED WORKING....
  1. Raster design bitonal image for contour follower
    By swyman in forum AutoCAD Map 3D - General
    Last Post: 2010-09-01, 03:30 PM
  2. What are you guys using to convert a dwg with an image to pdf format.
    By jmeyer.186809 in forum Land Desktop - General
    Last Post: 2009-09-14, 02:03 PM
  3. Convert to bitonal image
    By LanceMcHatton in forum Raster Design - General
    Last Post: 2006-04-27, 01:25 PM
  4. convert image into dwg
    By vergasov in forum ACA General
    Last Post: 2004-07-20, 10:12 PM
  5. convert image into dwg
    By vergasov in forum Revit - In Practice
    Last Post: 2004-07-08, 05:04 AM
