Thread: Dynamic Door Block
    2005-03
    From Kerala, Currently located at Bangalore, India
    95
    Question Dynamic Door Block
    Hi All,
    I have done a dynamic block for a door which I expect to behave based on some parameters and constraints. I have attached the block here. When the vertical flip parameter is used, the block becomes a mess by itself, by stretching the shutter length. Could anyone go through this and tell me what went wrong?
    2010-06
    91
    Default Re: Dynamic Door Block
    Hi-
    I had a look at your block. In order to control your door width you have a 90 degree angle stretch, which is very clever as long as it is in the upright position. When you flip your door across the horizontal axis, your stretch action for the door width is stretching 90 degrees but in the wrong direction. I would suggest that you abandon the flip across the horizontal axis and replace it with a rotate about your base point. A rotate in combination with the flip about the vertical axis should give you all the positions you need. Good luck!
    Sarah
    2010-06
    91
    On second thought, that doesn't fix the problem. I'll keep looking at it.
    2010-06
    91
    I'm not sure what caused this problem but when I deleted the flip parameters and then recreated them, they worked like they were supposed to. You might try redoing your flip paramters to see if that fixes it for you. If not, report back and maybe someone else can have a look at it.
    2010-07
    15
    Check this link:
    http://www.ellenfinkelstein.com/Auto...lock_door.html
    for sure you will find your mistake by reading that lesson, probably you did not select all objects when applied Flip action.
  1. 2016: dynamic block to write automatically door width value and door type accordingly.
    By architurk in forum Dynamic Blocks - Technical
    Last Post: 2015-08-24, 09:14 PM
  2. Simple dynamic door block
    By wotapain854183 in forum Dynamic Blocks - Sharing
    Last Post: 2011-07-18, 08:47 PM
  3. Error with dynamic door block
    By eclim in forum Dynamic Blocks - Technical
    Last Post: 2010-06-14, 07:42 AM
  4. Problems with Dynamic Door Block
    By mbergink in forum Dynamic Blocks - Sharing
    Last Post: 2008-12-20, 12:42 AM
  5. Dynamic Block door, update text automatically as door is changed
    By Matt Mercer in forum Dynamic Blocks - Technical
    Last Post: 2007-02-05, 01:41 PM
