Thread: Alignment Point Aquisition keeps resetting
    Active Member keelay711's Avatar
    2004-11
    San Diego, CA
    84
    Angry Alignment Point Aquisition keeps resetting
    I use otracking religiously, and so I keep the Alignment Point Aquisition (APA) option set to automatic. Ever since I started playing with lisps and and palettes (since AU), the APA periodically resets to "shift to aquire." I think I saw a blip about how palettes may have caused this bug. I have been unable to locate a system variable that controls this option. Is there a fix available?
    2001-05
    Austin, TX USA
    2,201
    Default Re: Alignment Point Aquisition keeps resetting
    POLARMODE System Variable
    Type: Integer
    Saved in: Registry
    Initial value: 0
    Controls settings for polar and object snap tracking. The value is the sum of four bitcodes:
    Polar angle measurements
    0 Measure polar angles based on current UCS (absolute)
    1 Measure polar angles from selected objects (relative)
    Object snap tracking
    0 Track orthogonally only
    2 Use polar tracking settings in object snap tracking
    Use additional polar tracking angles
    0 No
    4 Yes
    Acquire object snap tracking points
    0 Acquire automatically
    8 Press SHIFT to acquire
    This should be what your looking for.
    Glenn Pope
    Civil Designer/CAD Manager
    River City Engineering
    AutoCAD Civil 3D 2011 Ver. 3
    Windows 7 Pro 64bit
    I explode MTEXT.
    2004-11
    San Diego, CA
    84
    Thank you, kind sir!
    That did the trick. I suppose I was too eager to start setting variables from the AcadDoc.lsp I learned about at AU. Thanx again!
  1. HOW TO CHANGE THE starting point of an alignment
    By valejandro_ibarra in forum AutoCAD Land Desktop - General
    Last Post: 2008-08-04, 01:17 PM
  2. Alignment starting point
    By Civil-Tech001 in forum AutoCAD Civil 3D - Alignments
    Last Post: 2008-01-07, 03:36 AM
  3. Set Alignment Point Acquisition to Automatic
    By sturner in forum AutoCAD General
    Last Post: 2007-03-15, 08:21 AM
