Thread: multi circuit breakers
    2015-11
    Saint Louis, MO
    485
    Default multi circuit breakers
    has anyone come up with a solution to the 2008NEC rule that makes us use a 3-pole breaker for 3 individual branch circuits that share a neutral in a single homerun? i need the panel schedule to show the load names per circuit as if they are single pole breakers, but show them as a 3-pole breaker.
    Revit MEP Moderator mjdanowski's Avatar
    2007-03
    890
    Default Re: multi circuit breakers
    As the load names are almost always similar, we use a three pole circuit breaker and leave it at that. Its about as good as you will get.
    Matthew Danowski, PE, LEED AP BD+C
    Project Electrical Engineer
    Baltimore, MD
  1. Replies: 0
    Last Post: 2012-11-19, 07:14 PM
  2. 2013: Multi-Circuit Wiring Homeruns
    By EIT-JRB in forum Revit MEP - General
    Last Post: 2012-08-22, 09:42 PM
  3. 120V, 3 Pole, Multi Branch Circuit
    By Saimon in forum Revit MEP - Families
    Last Post: 2011-12-05, 07:25 PM
  4. Multi-circuit Junction Box
    By nickd.204205 in forum Revit MEP - General
    Last Post: 2010-06-24, 07:40 PM
  5. Multi Circuit Home Runs
    By msmith.161043 in forum Revit MEP - General
    Last Post: 2008-03-11, 04:56 AM
