Results 1 to 6 of 6
Thread: Erroneous "Cannot open central + local model" error message
    2007-10
    Portland, OR
    69
    Exclamation Erroneous "Cannot open central + local model" error message
    I have three models that are linked to each other and we are not able to open them in the same instance of Revit Arch 2011. Attached is the message.
    There is a core, skin, and interior (TI) model. We are not opening the centrals but this message comes up. It worked fine in 2010 but now in 2011 this erroneous message make us open multiple sessions of revit to work and we can't uses Transfer Project Standards. The only work around is to unload all the links in each file before trying to open them.
    Anyone else have this problem?
    2006-01
    4,516
    Default Re: Erroneous "Cannot open central + local model" error message
    Yep. File a Feedback Form about it, several of us already have, and the Factory is aware it s a problem. The more feedback they get, the more important it becomes. The functionality was altered in 2011.
    2001-12
    Irvine, CA
    7,567
    Removed or fixed...I guess that depends on your perspective. The programmers probably fixed the inconsistency since you are not allowed to open linked files simultaneously in the same session of Revit when worksets are not involved. Since locals and central "speak" to each other constantly they may have removed this "loophole" to avoid corruption that may or may not have been attributed to this practice. Just speculating wildly...
    2006-01
    4,516
    Thats fair. It was a poor choice of words. Having said that, i think the nature of a central/local relationship, plus every users *instance* of the Link being a quasi-time-stamped item, we really need it back the way it was.
    2007-10
    Portland, OR
    69
    Need is a good word. I've already submitted this to Autodesk but they have stopped communicationg with me on it so I thought I would see what others know. I just wanted to make sure I wasn't crazy.
    Thanks.
    2009-02
    Toronto, ON
    174
    Just wanted to voice my concern on this too. If this was in fact known to be a source of corruption I am all for getting rid of it. However, we became somewhat dependent on this functionality for copy/paste operations that we now cannot do. With that being said we have a work-around for the problem, and that is to do a direct copy/paste from the loaded linked file. It seems to work ok but is quirky.
  1. "Cannot open local and central model in same session"
    Last Post: 2023-01-26, 03:32 AM
  2. "Open Text Failed" error message???
    By KELLI in forum CAD Management - General
    Last Post: 2017-08-22, 12:18 PM
  3. "Other Users have saved changes to the Central File"..Error Message
    By kmarquis in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2011-04-05, 02:06 PM
  4. "Central File locked" message pops up when no one else is working on the model
    By Steve Mintz in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2006-08-08, 03:47 AM
  5. "central location cannot be found" error message
    By Revitator in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2006-05-02, 04:37 PM
