Results 1 to 7 of 7
Thread: General Notes/ Sheet Specification Management
    100 Club Limbatus's Avatar
    2010-04
    Gamehendge
    194
    Default General Notes/ Sheet Specification Management
    HI,
    Who has thought of a good way to manage Sheet Notes? We would like to have a template created in microsoft word from which we can select pertinant sections and link into our revit file. its a pain in the butt to have to export a PDF and re-import the file each time the notes are revised/ changed. Has anybody come up with a solution to this problem? We have decided not to do this internally within revit because it lacks many of Word's helpful fromatting tools. Any advice or recommendations would be greatly appreciated. thanks - csdg
    2008-11
    Australia
    467
    Default Re: General Notes/ Sheet Specification Management
    I have done all of my notes as families using a generic annotations template.
    In these I have been able to do such things as set up variable inputs for certain notes (ie design loads, regions, categories etc)
    I just load the family in to revit, drag and drop it onto any sheet where I need it, usually a cover notes page, and then alter properties of the notes as required to update any variables as mentioned already.
    You could even go as far as making note 'blocks' for example sub notes within a normal heading, you could make these able to turn on/off with a yes/no toggle in the properties.
    Pittsburgh, PA USA
    1,906
    Graphic items we have in a legend view in our template. Pure Text notes, abbreviation lists, etc. we have built into Key Schedules. The advantage there is that these views can be imported from project to project, or from the Template, etc. You can then edit them relatively easily on a per project basis.
    There are several API programs that will read/excel information into a Revit Schedule which works fantasically with Key schedules.
    2010-04
    Gamehendge
    194
    Thanks for the replies. I'm curious about using the API to import from excel. I know nothing about programming, but I just stumbled upon this thread.
    http://forums.augi.com/showthread.ph...ight=api+excel
    It looks like it might be helpful. thanks again.
    I could stop if I wanted to Dave Jones's Avatar
    2005-12
    San Luis Obispo, CA
    283
    Quote Originally Posted by csdg.dsgn View Post
    the code posted by Alfredo near the end of the thread is what I'm using to get key notes from Excel to a Revit key schedule. It works a charm!
    Dave Jones
    Drafting & Design Plus (DDP)
    Revit 2013 One Box
    Win 7 Pro 64 bit - Intel I7-860 @2.8GHz
    12GB DDR3 RAM - GeForce GTX260
    2012-06
    2
    This is still not working for us. We are using 64 bit but I have also tried 32 bit and no luck on either.
    2005-10
    2
    Karalon10 this technique sounds very interesting and might be exactly what I'm looking for. Can you post an example of what you've done with the generic annotation template.
  1. How do YOU do your general notes?
    By mattw in forum Revit - Platform
    Last Post: 2009-09-21, 05:25 PM
  2. General Notes / Key Notes
    By lonewolfjustin in forum Revit MEP - General
    Last Post: 2008-11-25, 01:31 AM
  3. General Notes Sheet - Best Practices
    By cdchristian in forum Revit Architecture - General
    Last Post: 2006-12-06, 03:17 PM
  4. General Notes
    By Chris DiSunno in forum Revit Architecture - General
    Last Post: 2005-03-16, 08:45 PM
