Results 1 to 10 of 13
Thread: entmake
    2010-08
    6
    Default entmake
    Hi, I am trying to entmake a INSERT (block) from a different directory. only if I inserted first the block, then the entmake , the block will appear.
    How do I entmake blocks from different directories without inserting the blocks in the drawings first.
    Thanks in Advance
    2010-08
    6
    Default Re: entmake
    Quote Originally Posted by gagage View Post
    Thanks in Advance
    The codes are as follow:-
    (entmake'((0 . "insert") (8 . "0") (70 . 2)(2 . "c:\\lib\\part_0023.dwg") (10 0.0 0.0 0.0)))
    it return nil
    until I insert the block into the drawing and delete it.
    Thanks Again
    I could stop if I wanted to Tharwat's Avatar
    2010-06
    477
    Default Re: entmake
    Hello,
    I think entmake won't work that way, and to use the command would allow you to
    reinsert the same last Block name inserted into your drawing.
    (while (setq pt (getpoint "\n Specify the Block Insertion point: "))
    (command "_.-insert" "" pt "" "" "" )
    it is continuous inserting Blocks.
    Welcome to AUGI
    Tharwat
    2010-08
    6
    Default Re: entmake
    Quote Originally Posted by tharwat313 View Post
    Hello,
    Welcome to AUGI
    Tharwat
    Thanks Tharwat,
    I am trying to use entmake so that I can insert many parts into the drawings quickly. I have tried using command insert , it seems that it is much slower.
    I am inserting a hundreds of block from a text file.
    Any other solution.
    Thanks
    2010-08
    6
    Default Re: entmake
    Thanks Tharwat,
    Any other solution.
    Thanks
    is there a code I can define the directory of the block I am inserting from?
    2010-06
    477
    Default Re: entmake
    Here is the rule of the Block entmake, and I think the problem is with the Block Path itself, because I tried it with normal existed block in my drawing and it works normally.
    So don't worry somebody would help you with it very soon.
    (entmakex (list (cons 0 "INSERT")
    		(cons 2 "BlockName")
    		(cons 10 '(0 0 0))
    Please correct your Codes accordingly.
    Regards,
    Tharwat
    2010-08
    6
    Default Re: entmake
    		(cons 10 '(0 0 0))
    Regards,
    Tharwat
    Thanks Tharwat,
    It works only when there is a existing block in my drawing. is there a parameters i can set the path.I tried to insert the block and then cancel it. it still works.
    Thanks Again
    2010-06
    477
    Default Re: entmake
    This is what I indicated to it before.
    it still works.
    Actually there must be, and I tried to insert an external block to current drawing but it's failed.
    You will get it work very soon.
    Regards.
    2010-08
    6
    Default Re: entmake
    Regards.
    Still searching for a solution to link the external block into the dwgs..
    2002-12
    77
    Default Re: entmake
    I believe that the block definition must exist before you can make an insert from it.
    You have 2 choices
    VLA-INSERTBLOCK
    or
    (entmake
    		(list
    			(cons 0 "BLOCK")
    			(cons 2 BlockName)
    			(cons 70 2)
    			(cons 10 (list 0.0 0.0 0.0))
    			(cons 8 "0")
    ***ADD YOU ENTMAKE OBJECTS HERE
    	;; Write block end sub-entity
    	(entmake
    		(list
    			(cons 0 "ENDBLK")
  1. Entmake UCS - error
    By krkeec763189 in forum AutoLISP
    Last Post: 2011-11-19, 08:09 AM
  2. Help with entmake syntax
    By fclao in forum AutoLISP
    Last Post: 2010-05-25, 09:12 AM
  3. Example of EntMake
    By ccowgill in forum AutoLISP
    Last Post: 2009-08-24, 08:37 PM
  4. Entmake UCS
    By Takuwind in forum AutoLISP
    Last Post: 2006-08-04, 08:01 PM
  5. UCS vs entmake
    By scwegner in forum AutoLISP
    Last Post: 2005-08-26, 04:04 AM
