I am running AutoCAD 2010 with AutoCAD Raster Design 2010. I am plotting the Raster Image along with some Vector to a PDF. But the Raster Image does not show up in the PDF. It does show up in the preview. Any thoughts?
Are you using the AutoCAD DWG to PDF.pc3 to plot? Check the line merge option in the properties.
J. Murphy
AKA
Murph
The former AutoCAD MAP3D Power User
I was instructed to use Bluebeam for our PDF. I did use Dwg to PDF, and yes I checked the line merge, but I get the same result. Everything looks good in the preview, but only the vector comes through. Everything worked fine a couple of days ago. I remember filtering out some paper sizes, which required me to save my pc3. I also noticed that it does take a conciderable amount of time to process my raster plots. Whether it is a PDF or one sent to the printer. I attributed it to the amount of raster in the dwg. The files are around 1 - 1.5 mb's.
is the image in a clipped viewport? with some drivers that seems to be an issue. I have had more reliable results clipping the image, and leaving the viewport as a a rectangle
Officially Awesome
