Anybody know if it is possible to move a corridor down few cm after it is created?
Or that is impossible?
If it is OK, how to do it?
Thank you.
Nat
Thank you.
Nat
Lower the profile using the Raise/Lower PVI's command in the geometry editor.
Jeff Paulsen
Thank you for the answer.
This I know, but the problem is that I have an alignment for railway, not highway. I wanted to make a corridor that reflects the surface of the concrete slab which is 341mm lower than the alignment.
Use a generic LinkOffsetElevation subassembly to go from the assembly down 341mm. Set the omit link property to yes. Connect the other subassemblies to this one.
Thank you David for the hint!
I will try tomorrow your advise!
