Thread: Changing Wall thickness
    2006-09
    Adelaide, Australia
    23
    Default Changing Wall thickness
    Hi Everyone,
    I'm trying to change a wall thickness from 90mm to 190mm whilst keeping the exterior dimension. i.e. extend the new thickness to the inside. I have tried to constain the exterior wall side to the floor and also a detail line but this doesn't stop the wall from extending out past it. It is extending to the exterior of the wall. Any ideas?
    Karalyn
    2003-11
    442
    Default Re: Changing Wall thickness
    Change the Location Line of your walls to either Core Face: Exterior, or Finish Face: Exterior, depending on what 'line' you want to remain in place as you change the thickness.
    2006-09
    Adelaide, Australia
    23
    It was set to core face exterior and i just changed it to finish face exterior but it still does the same thing.
    2006-09
    Adelaide, Australia
    23
    Sorry should have tried Finish face interior before I posted. That works. Thanks heaps for your help.
  1. 2014: IFC wall Thickness
    By b.boyard in forum Revit - Platform
    Last Post: 2014-08-04, 08:34 AM
  2. Changing thickness of Property Line
    By abink in forum Revit Architecture - General
    Last Post: 2012-02-15, 02:37 AM
  3. Wall thickness
    By bengo in forum Revit Architecture - General
    Last Post: 2008-04-26, 04:41 PM
  4. Different wall thickness
    By charles.wong144891 in forum Revit Architecture - General
    Last Post: 2007-08-24, 08:57 AM
  5. Changing Line Thickness
    By .chad in forum ACA General
    Last Post: 2006-05-03, 06:00 PM
