Thread: 2011 Panelboards-Wire Size
    2007-08
    Salt Lake City, Utah
    12
    Default 2011 Panelboards-Wire Size
    Hello, I was told that this was the place to make requests, Last year we send some information to Autodesk (with an PDF diagramming) about what the Industry, Meaning Electrical< required in a panelboard schedule. And to our surprise we go 95% of what we requested. As you know panelboard now have template. Ding, They now have nore controllable parameters, Ding. and they are customizable, Ding. Excellent. The one thing I would suggest and that we need is the Wire Size parameter. Should be an easy fix. We would like in addition to the wire size parameter parameters for the individual Conductor, Ground, and Neutral. Actually, we just need the Conductor. Currently right now when you add the wire size is displays - 1 #12, 1 #12, 1 #12. For schedules that is a huge category and I have never seen all of that on a schedule. mostly what I see is that there a column for wire size and is just has 12 for a #12 wire. What are your thought. Thankfully we have not done a project to completion in 2011, due to the fact that the architects have not sent a 2011 project.
    Certifiable AUGI Addict
    2004-05
    St. Louis, Missouri
    3,135
    Wink Re: 2011 Panelboards-Wire Size
    This would probably better posted in the Revit MEP Forum.
    Nonetheless, it's good to hear about all the improvements on the MEP side.
    cheers
  1. Volt Drop & Wire Size
    By Admiral McAwesome in forum Revit MEP - General
    Last Post: 2017-06-01, 02:39 PM
  2. 2013: change wire size tag from 1-#12,1-#12,1-#12, to just #12
    By bulletproofx352446 in forum Revit MEP - General
    Last Post: 2014-03-06, 05:08 PM
  3. 2011 Panelboards-Wire Size
    By jarom in forum Revit MEP - General
    Last Post: 2010-08-18, 07:00 PM
  4. Displaying Wire Size
    By wags5116 in forum Revit MEP - General
    Last Post: 2009-09-28, 07:55 PM
  5. AutoCAD MEP 2009 Wire size
    By edsamour in forum AMEP General
    Last Post: 2008-07-09, 08:22 PM
