Results 1 to 10 of 11
Thread: creating a custom triangular waffle slab using a curtain panel pattern based component
    2010-08
    3
    Angry creating a custom triangular waffle slab using a curtain panel pattern based component
    This is my first post on this forum and I will buy whomever solves this an ice cold coca-cola classic! I am creating a sloping (curved) roof structure waffle slab. The twist is that we want it to be a custom triangular waffle pattern. It seems to me that in Revit 2011 the curtain panel pattern based system applied to the roof surface should do the trick, but I am having some difficulty getting my desired result. I have attached the component that I believe should work, but it of course does not. Basically I am needing to create an extruded triangle with a void extruded to create the waffle pattern. If anybody has the secret formula, or some advice for creating this type of system I would be eternally greatful!
    Thanks in advance!
    Certifiable AUGI Addict cliff collins's Avatar
    2003-09
    St. Louis, Missouri
    3,071
    Wink Re: creating a custom triangular waffle slab using a curtain panel pattern based component
    Can you post an sketch of the roof form you are trying to achieve?
    That would help us understand how to solve the problem better.
    cheers
    Cliff B. Collins, Registered Architect / BIM Specialist
    St. Louis, MO
    2010-08
    3
    Default Re: creating a custom triangular waffle slab using a curtain panel pattern based component
    Sorry about the confusion. It is somewhat of a complex for we are hoping to achieve as simply and efficiently as possible. Here are a few sketchup images that should help illustrate what we are looking for.
    2008-11
    Australia
    467
    Why wouldnt you achieve this with just a flat slab and beams?
    Alternatively, you could simple put in deeper sections of slab to form the waffle portions.
    ie model one flat slab at 200thk, and then a series of 600thk portions to form the beams.
    2008-03
    29
    Quote Originally Posted by karalon10 View Post
    How would a flat slab help? The roofs is double-curved as far as I can see.
    2003-09
    St. Louis, Missouri
    3,071
    Thanks for the images.
    If you already have it in SU, you could import the .skp file into a Mass family, load into your Revit project, and the convert faces to Revit Walls, Floors, Roofs, etc. Not an ideal solution, I know.
    Are the beams actually radiused? or segmented to approximate a curve? This distinction
    is critical in determing modeling methods and constructability.
    You COULD use the Conceptual Massing tools as you initially suggested to create the curved roof form, then with an Adaptive Component create the triangular shape and apply it as a pattern-based curtain system?
    Take a look here for some similar examples:
    http://buildz.blogspot.com/
    There are quite a few posts there which deal with the Conceptual Massing tools,
    so be sure to look at older posts as well.
    For a true BIM, the Structural Engineer would be modeling the concrete waffle slabs--
    so you might also post this challenge in the Revit Structure Forum, and see if there are any advanced users who may have modelled something like this in RS. LOL!
    cheers
    cheers
    St. Louis, MO
    2010-08
    3
    Hey everybody, thanks for your help. I ended up making my component another way.
    I am having a seperate issue that maybe somebody out there can help me with. For some reason my roof components are having trouble filling in the edges as partial panels. I know that there are ways to fix this. Here is the strange bit: I have modeled my roof as an in place mass within my overall project file. When I am outside of the family there are a handful of panels that are not cutting along the roof profile as they should (roof_1 image). When I edit in place the incorrect panels shift to a different location (roof_2 image). I'm thinking this would be an indication of a file-size memory related issue?
    Initially I modeled my roof as a seperate family and inserted as a generic model into my overall project. This gave me a similiar issue: In the roof family the edges were perfect with zero overhanging panels, but when I brought the family into the project the overhanging panels appeared. Again, this leads me to believe there is some graphic, or hardware issue to blame?
    Anybody??
    John
    2010-08
    4
    Quote Originally Posted by jiiams View Post
    Thanks in advance!
    I maybe shot for suggesting this, but Rhino with the grasshopper plug-in (it's free) would be perfect for what you need.
    2008-11
    Australia
    467
    Quote Originally Posted by thomas.163390 View Post
    It would help because you can then later modify the slab elements to make it a falling/sloped surface. It's quite easy done with the modify sub-elements tool.
    2005-07
    Somewhere in the BIM world
    3,140
    Anybody??
    John
    Change the Border Tile to empty and create an Adaptive Component to fill the gap.
  1. 2012: Curtain Panel Pattern Based.rft Question
    By Jarod in forum Revit - Conceptual Design Tools
    Last Post: 2012-03-12, 06:42 PM
  2. 2012: pattern-based panel cut error
    By damon.sidel in forum Revit - Conceptual Design Tools
    Last Post: 2012-03-12, 03:42 PM
  3. Pattern based curatin panel with gap??
    By tampac66 in forum Revit Architecture - General
    Last Post: 2010-10-19, 09:17 PM
  4. normal vs. pattern based curtain wall panel
    By Ning Zhou in forum Revit Architecture - Families
    Last Post: 2010-09-13, 01:41 PM
  5. Curtain Panel Pattern Based
    By PaperStreet SoapCO in forum Revit Architecture - Families
    Last Post: 2009-06-08, 08:07 PM
