Thread: Filters including graphic override?
    2010-04
    30
    Default Filters including graphic override?
    Hi,
    The use of Filters is great for many applications - but currently I manually setup the graphic overrides for an applied filter in each view.
    Is their a faster approach to using Filters, preferably a way to save graphic overrides with the filter? For example, applying a "red wall filter" that would automatically color the filtered walls red without me having to specify "red" each time.
    2006-05
    835
    Default Re: Filters including graphic override?
    View templates save both the filters and the override configurations.
    After setting up the view if you save the confiuration it will be stored as a view template and can be used in other views and projects.
    AJS
    BIMM Consultant
    www.GHD.com
    2010-04
    30
    Thanks, I've used view templates previously as a complete "view settings setup" template and did not realise, that it could apply only to the applied filters as a specific configuration on part of the view.
    Works perfectly.
  1. layer filters, including and excluding
    By cadtag in forum AutoCAD General
    Last Post: 2012-02-23, 06:02 PM
  2. text parameter graphic override
    By cbaze in forum Revit Architecture - General
    Last Post: 2009-05-04, 08:20 PM
  3. using filters to override linked plans
    By williamsmitchell in forum Revit Architecture - General
    Last Post: 2008-05-02, 08:19 PM
  4. override phasing graphic overrides?
    Last Post: 2005-09-06, 04:56 PM
