Help guys.
A client (State DOT) has provided us survey files produced in Microstation and Inroads. When I try to use "DGNImport" to bring the drawing in, I can't. I get the error message "This DGN file does not contain any models that can be imported into this drawing". The files contain a wide variety of extensions (.inp, .dra, .prn, .mmd, .dpw, .dpf, .fil) in addition to .dgn. Some of these might relate to their survey program instead of Microstation, I don't know.
Log files I can read suggest that they did create a TIN and alignment, but don't know how to get the data.
Unfortunately, the client has indicated to us that they will not convert to AutoCAD on their end as it is against their policy, and we have to deal with it ourselves. (A little disappointing, but I guess I can't blame them.)
Everything I can find on the process says it is easy to bring in DGN by DGNImport, but every comment I read on doing it says it is nearly impossible to do it through AutoCAD and that doing it through Microstation is better.
This is a potentially big client for us that we hope to do more work for in the future. Do we have to change to Microstation, or can we get AutoCAD (Civil 3D 2011) to do this? (Are you reading this AutoDesk?)
