Thread: Conceptual Massing (Surfaces)
    2010-08
    4
    Default Conceptual Massing (Surfaces)
    Another one for you guys
    Having problems when dividing and editting surfaces within the conceptual mass family. I have attached a couple of pics for reference.
    The first ones (Conceptual Massing) show the object we need to create (custom curtain wall as a roof element) note how the mullions follow the line of the edge of the mass object and there is a mullion placed along the edge quite neatly as well..
    Now, if you refer to the other pictures (New Mass) I am unable to achieve the same result! the division runs flat ignoring completely the shape of the surface.
    Anyone knows if there is a way to manipulate this?
    Thanks
    Certifiable AUGI Addict
    2004-05
    St. Louis, Missouri
    3,135
    Wink Re: Conceptual Massing (Surfaces)
    All AUGI, all the time AP23's Avatar
    2005-11
    530
    Default Re: Conceptual Massing (Surfaces)
    It looks like you created a square shape and then used the void the cut out the proper shape. Only then the UV runs in the direction of the original shape. If you create the shape as is, by using arcs, then the UV grid will follow the contour.
    2010-08
    4
    That makes alot of sense, I have managed to do it now.
    Thanks!
  1. Add Formit to conceptual massing interface
    Last Post: 2013-01-03, 06:13 AM
  2. Conceptual Massing Question
    By kathey1 in forum Revit Structure - General
    Last Post: 2011-09-06, 12:22 PM
  3. Massing/Conceptual Design Forum
    By Steve_Stafford in forum Revit - Conceptual Design Tools
    Last Post: 2010-09-02, 01:13 PM
  4. Conceptual Massing: Offset
    By jpyeatt in forum Revit Architecture - General
    Last Post: 2009-12-15, 06:57 PM
  5. 2010 Conceptual Massing Tools
    By Dimitri Harvalias in forum Revit Architecture - General
    Last Post: 2009-05-26, 06:23 PM
