Thread: Locking Floor edge to beam edge
    2008-05
    38
    Default Locking Floor edge to beam edge
    I've locked a floor edge to a UB beam edge while in the sketch mode of the floor, so if the beam size changes, the floor edge will go with it. This works if I change the size to another UB section size, but if I change it to a UC section size working as a beam, it screws the edge up. Is there any way I can fix this?
    Thanks.
    2004-05
    Los Angeles, CA.
    111
    Default Re: Locking Floor edge to beam edge
    you could try locking a ref plane to the original bm. and then lock the floor to the ref plane.
    Its a suggestion I guess.
  1. Flip Edge Direction of "Add Edge" in Conceptual Mass
    Last Post: 2012-11-14, 01:55 AM
  2. Place a plane on a tangent edge of a circle with a parallel surface or edge.
    Last Post: 2010-09-22, 12:51 PM
  3. Slab Edge Profile not loading under Floor-Slab Edge
    By John Anderson in forum Revit Architecture - General
    Last Post: 2008-06-16, 05:44 PM
  4. Isolating edge jitter and/or edge overhang
    By pauljordan in forum AutoCAD 3D (2007 and above)
    Last Post: 2006-06-07, 09:33 PM
  5. Wall edge stuck to floor edge
    By iru69 in forum Revit Architecture - General
    Last Post: 2006-03-02, 08:55 PM
