Thread: Help! Existing Metal Decking Visibility...
    2010-08
    2
    Default Help! Existing Metal Decking Visibility...
    Hello all, I would like to know how to make visible the components on an existing composite metal deck slab. It seems that when it is exisiting it does not show the components like when it is set to new construction. Is there a way around this? Your help is greatly appreciated....
    2005-07
    Somewhere in the BIM world
    3,792
    Default Re: Help! Existing Metal Decking Visibility...
    The display of phased elements is controlled through Phase Filter.
    2010-08
    2
    Thanks for your help. I tried changing settings. I have 2 structrual floor slabs with metal decking and I would like to show the New with a thicker cut line and the Existing with a lighter cut line as well as both showing the decking. So far if I modify the phase filters settings to show New and Existing "by category", they both display the metal decking, but the thickness of the cut line is the same. If I switch, let's say Existing to override, I do get thinner lines, but I loose the decking and my existing slabs look like a solid slabs...any other words of advice will be appreciated...
    2008-12
    2
    Have to been able to find a solution for this? I am having the same issue with my existing floor slabs not being visible.
  1. 2012: Existing Graphic Overrides Delete Metal Decking
    By adasso2 in forum Revit Architecture - General
    Last Post: 2012-05-02, 04:49 PM
  2. Corrigated Metal Decking
    By mgore.139566 in forum Revit Structure - General
    Last Post: 2008-05-08, 05:55 PM
  3. Looking for a metal decking linetype
    By rolibolibo in forum AutoCAD Customization
    Last Post: 2007-03-03, 06:54 PM
  4. Modeling- Structural Metal Decking
    By pwmsmith in forum Revit Architecture - General
    Last Post: 2004-05-07, 07:41 PM
  5. Metal Decking Wall Style
    By Clyne Curtis in forum Revit Architecture - General
    Last Post: 2004-04-10, 12:10 AM
