Thread: wall clean up
    2006-04
    Default wall clean up
    how do you clean up this type of wall, a cavity wall connects to a brick wall, see attached image.. thanks
    2008-11
    Australia
    754
    Default Re: wall clean up
    I think the best you could hope to achieve (as this is how it will be built in reality anyways) is to "disallow wall joins" for the brick wall, and stop it 10mm (grout distance) before the veneer wall. This will allow your veneer wall to run straight through. The 10mm gap is so small you wont notice it in plan, but a blow up detail of it would be correct anyways.
  1. Wall clean up
    By dzatto in forum Revit Architecture - General
    Last Post: 2010-06-26, 04:53 PM
  2. Wall Clean up
    By azmz3 in forum Revit Architecture - General
    Last Post: 2009-01-30, 08:32 PM
  3. Wall Clean Up
    By bgrinnell in forum Revit Architecture - General
    Last Post: 2008-10-24, 12:26 PM
  4. Wall Clean-up
    By bnutkins in forum AutoCAD General
    Last Post: 2008-01-21, 01:48 PM
  5. Wall Clean Ups
    By H-Angus in forum ACA General
    Last Post: 2006-03-16, 09:19 AM
