how do you clean up this type of wall, a cavity wall connects to a brick wall, see attached image.. thanks
I think the best you could hope to achieve (as this is how it will be built in reality anyways) is to "disallow wall joins" for the brick wall, and stop it 10mm (grout distance) before the veneer wall. This will allow your veneer wall to run straight through. The 10mm gap is so small you wont notice it in plan, but a blow up detail of it would be correct anyways.
