Thread: Structural usage - Non-bearing structural walls
    All AUGI, all the time Bryan Thatcher's Avatar
    2007-09
    Raleigh NC
    753
    Default Structural usage - Non-bearing structural walls
    I have walls that are not shear walls and are non-bearing. So I have them set to non-bearing. But when I set the view to structural, they disappear. They need to be on the structural plan. Why isn't there a structural usage for walls that is neither. I can use the combination, but they are actually the opposite of that. Any ideas? Thanks.
    Bryan Thatcher
    Structural Design Technician
    Clark-Nexsen Architecture & Engineering
    Member jcapp's Avatar
    2003-12
    Lancaster, Pa
    49
    Default Re: Structural usage - Non-bearing structural walls
    Perhaps you need to set the view to coordination. Quite often if walls are not structural in nature, i'll just link a cad file with just the walls into the required view. That way they show only on plan.
    2009-03
    43
    Set it to structural as you normally would. Use the Underlay layer to show the same layer - this appears to always be a 'coordination' type view and shows all walls 'under' the main view. So architectural walls will show up as halftone in a structural view. You can change that behavior as well I think, but we like the style and behavior and haven't tried to modify it.
  1. Structural Framing - Structural Usage
    By Davied2 in forum Revit Architecture - General
    Last Post: 2010-04-07, 08:45 AM
  2. Change Structural Usage on Walls
    By pdavis in forum Revit - API
    Last Post: 2009-02-04, 08:45 PM
  3. Non-load bearing walls not showing up when Discipline is Structural
    By johk in forum Revit Structure - General
    Last Post: 2008-01-23, 03:00 PM
  4. Walls - Structural Usage : Bearing and Non-bearing
    By rmejia in forum Revit Architecture - General
    Last Post: 2006-11-28, 04:35 PM
