Results 1 to 8 of 8
Thread: Can't Share a nested family
    2008-07
    Brisbane (Ex. Swedish)
    346
    Default Can't Share a nested family
    Hi,
    I am trying to create a family to use for sound barriers on plant platforms. At this stage all i want to show is the posts and the girts.
    It is a Generic Model family. I have the family working ie i can place it and change number of posts etc.
    The problems I have that i am not sure how go about are;
    1. I want to be able to tag the posts in the model. The posts are set in a nested family and when I change them to Shared i can’t “map” the parameters in the host family.
    2. I don’t seem to be able to array or lock my girts.I have added Parameters to for controlling the top and btm girt and it doesn’t work – am not sure what i did wrong.
    Any Suggestions on the above would be much appreciated.
    Thanks,
    J
    All AUGI, all the time Alex Page's Avatar
    2003-07
    Wellington, New Zealand
    793
    Default Re: Can't Share a nested family
    Quick responce (no time sorry!)
    item 1. = the nested component parameters (if shared) need to be changed to instance based only
    Alex Page
    RevitWorks Ltd
    Check out the Door Factory, a door maker add-in for Revit
    2008-07
    346
    Thanks mate,
    I tried to change the parameters in my nested family ti instance but I still couldn't tag my post. The nested family contains the post and girts. It is then nested into a generic linebased famliy which is using an array.
    I will play around with it during the weekend when I have some time
    Thanks,
    J
    100 Club Jmickledesign's Avatar
    2004-05
    Los Angeles, CA.
    111
    I went into each nested family and made sure that all of them were shared. I believe your original column family is not shared. You then have to go into the bay family and reload the shared column into that family. Make sure to trickle it all down the line then you will have it.
    Worked for me with the columns. Didn't try the girts yet.
    Good Luck,
    2008-07
    346
    Thanks mate,
    For some reason it didn’t cross my mind to check the column family within the nested family?????
    J
    2004-05
    Los Angeles, CA.
    111
    Glad I could help.
  1. Nested Void Problems on Shared Families (doesnt cut nested family if its shared)
    By Miheal_Keehl815723 in forum Revit Architecture - Families
    Last Post: 2011-09-27, 02:23 AM
  2. Nested nested family label
    By clog boy in forum Revit Architecture - Families
    Last Post: 2009-09-24, 01:04 PM
  3. Adjustable Muntin family ( was>I thought i'd share this one)
    By Daniel Hurtubise in forum Revit Architecture - Families
    Last Post: 2005-06-20, 07:28 AM
  4. nested + nested window family with louvre arrays
    By gnl in forum Revit Architecture - Families
    Last Post: 2003-07-11, 01:54 PM
