Thread: Wall dew point calculation
    2007-03
    Salt Lake City
    360
    Default Wall dew point calculation
    Is there a way to calculate the dew point in a wall assembly?
    If a wall is made up of individual materials with a given thickness, and I create a R-Value parameter that I can assign to materials, walls, roofs, etc, is there a way to calculate the total R-value of the wall to determine the dew point location?
    I know I need to add the formula to determine where the dew point occurs in the wall assembly. What I can't figure out how to do take each material that makes up a wall type and its corresponding R-value and calculate each portion and add together as a complete assembly.
    2006-01
    306
    Default Re: Wall dew point calculation
    I saw a demonstration put on by Dupont (makers of Tyvek) that did exactly what you're talking about. It stepped through a bunch of different wall material layer configurations and let you pick the best one for your situation, then changed the wall type in Revit to that type.
  1. adding a wall to a room area calculation
    By tecnicheparametriche in forum Revit Architecture - General
    Last Post: 2011-04-23, 07:01 PM
  2. Wall point editing.
    Last Post: 2008-07-12, 03:09 PM
  3. Wall-Based Toilet Insertion Point
    By lhanyok in forum Revit Architecture - Families
    Last Post: 2007-05-31, 05:34 PM
  4. Total Linear Wall Length Calculation from Schedule?
    By artitech in forum Revit Architecture - General
    Last Post: 2006-05-16, 09:11 PM
  5. Trouble snapping to wall core inside corner point
    By Rhythmick in forum Revit Architecture - General
    Last Post: 2004-11-05, 03:48 AM
