Thread: Revit MEP System Browser Output
    2010-06
    2
    Default Revit MEP System Browser Output
    I've created several systems in Revit MEP and calculated the system pressure drop. Is there any way to out put the pressure drop information for each system (and ideally for each section) to a text or excel format so I can keep a record of it?
    AUGI Addict mattw's Avatar
    2002-06
    North Central CT
    1,010
    Default Re: Revit MEP System Browser Output
    You can create a schedule for DUCTS and add PRESSURE DROP and SYSTEM NAME (and any other fields you'd like) to the schedule. You can then export to a CSV file and open with Excel.
    Not sure if this will work for you or not.
    Matt
  1. System Browser
    By d-scheller in forum Revit MEP - General
    Last Post: 2011-07-27, 06:16 PM
  2. system browser Revit 2011
    By PTofiq in forum Revit Architecture - General
    Last Post: 2010-06-24, 06:19 PM
