Please let me know simple technicques to assign/applying masonry wall loads on floor slab?
How about LineLoad following the path and the weight of the wall? What do you expect to achieve and what else could it be?
BR Matti
Yes i apply line load. But wanted to know if there is an option to model masonry walls.
Hi, this aspect opens a totally new view to the problem.
So we must have a proper density material to model the whole wall first, then
we should be able to decide the rigidity / stiffness of the brick-structure.
Is it load bearing? How it is fixed to the structures around ? And so on..
I think, that it is not necessary very much advisible to go that way.
There might lurk too much problems ;>)
BR. Matti
